Removed the stainless steel screws to replace the stainless steel trim tabs on my boat (which is kept in saltwater) and discovered the shaft of the screws were almost entirely eaten away. Apparently this is not electrolysis but is crevice corrosion that occurs in pockets of stagnant (no oxygen) water around the fitting. So what would be the best solution - silicon bronze? That would mean dissimilar metals (with SS trim tabs). Should I use bronze screws? Or, should I use bronze bolts so that I can run a bonding wire between them inside the hull?
