MickLovin
Master Chief Petty Officer
- Feb 18, 2013
- 822
Hi all firstly I will apologise if I have put this in the wrong category, I have a 17ft half cabin which I have just given a one pack coat of black gloos enamel to the bottom after hours of stripping the original terrible paint job with 3 different coats of paint to get through. After 2 days of stripping the paint I them pressure cleaned it and then sanded to a 180 grit, I then applied my one pack paint to the bottom. My question is after seeing how well it came up on the bottom I am thinking of putting a two pack coat on the sides, The sides have been previously sanded but I painted them with the wrong paint which I will now take off, not a big job really cause the paint was so bad it comes off with the pressure cleaner under it.
So what type of two pack paint do I use as I have never used a two pack. How do you use a two pack paint and should I undercoat the sides before the paint. I did on the bottom because of the crap paint previous.
Any help is appreciated
