azmav
- Apr 16, 2013
- 61
Hey all, getting back to this job I started early part of last summer but gave up after the heat got too bad here in Arizona. I have some complications to overcome and I am looking for some advice on what is most crucial and any tips or tricks. The issues are thus,
1. Once the floor came out, the extreme heat (121 degrees Fahrenheit some days) caused to bow to sag against the front bumper where the ratchet point is. Please see pictures.
2. The boat sat for 5 years before I got it and has some depressions where it sat on the bunkers of the trailer all along the strakes.
Top cap is off for transom replacement, but should I put the cap back on before attempting stringers and floor? (keeping in mind this bayliner had limited space around the area of the bilge so doing all that with the splashwell in the way might be tricky) Also, I need to pull the sides of the bow back together a bit to help pull the front end back down. Thinking about something like what Opps did with a machine threaded rod or using cables and turn buckles.
