Re: My Bow eye ripped off while driving!
Now, I don't have to really worry about fixing the hull? Basically just need the new hardware (higher quality nuts and U-Bolt). I'll take pictures from the inside in a few minutes and get them on here. If somebody could explain their process in steps on the matter that would be extremely helpful.
Thanks for all the input so far.
-Christian
yes, from the picture you posted, there is no damage - on the outside at least - to be fixed.
Mask the hull around your work area and cover wherever you don't want the sealer to get to.
Get new hardware and insert it from outside the boat first.
When it is about 1/2 an inch or so above the hull, apply 4200 (removable) or 5200 (perminant) 3M marine sealer.
Tip:
Don't apply the sealer before you insert the U-Bolt in. The threads will be covered with sealer and it will make tighting the nuts from inside very hard specially if it start setting.
From the inside, and assuming no damage of any kind happened to the fiberglass - apply sealet and insert the backing plate and tighten the nuts.
