seanymph85
- Nov 5, 2013
- 199
I have a 1985 SeaNYmph 14R V-Hull boat, Big water model I believe and am wondering about how to replace leaking rivets on this boat. They are not a pop rivet of any kind that I can see nor are they a rounded head. The surface of the head inside and outside of the boat is flat.
I understand that you can try to "buck" them to tighten "seal" but have not tried that yet. The main area that appears to have any leaks is in the bow. From what I can tell from prior posts on this site and elsewhere the type of rivet to use is a closed end blind rivet. I contacted a link for a place in Michigan that I found on this site that sells them.
Does anyone have suggestions as to any special type of pop-rivet tool that is required to properly set these kind of rivets? Any special sealer suggestion, or another type of rivet that would be better. I think on one post if mentioned 5200and thought that referred to a sealer but I am not sure on that.
Any suggestions on this as to tools to use to "buck" these rivets and or tools or materials to replace them is appreciated.
