1974 14ft Dixie malibu
fishmonster13
just picked up a 1974 Dixie malibu 14 footer, came with a 72 4.5 mercury outboard. this is going to be a budget build fishing boat, will sell the little outboard and put a 25hp + motor on it, transom is rotted, front deck is rotted and pretty sure the bench is rotted as well it kinda bulges out in the middle, should be a fairly easy build for a glass boat.1471846_789090624439472_908577634_n.jpg1486758_789090671106134_1697843010_n.jpg1507155_789090551106146_218409654_n.jpg1525191_789090591106142_390218112_n.jpg
fishmonster13
Re: 1974 14ft Dixie malibu
started on it the other day, pulled up front deck and found a bunch of mulch, making me itch just thinking about it. deck is out, will do the cap next on the nose and get the bench and transom, but need to get a new grinder first the sawzall just take to long and the blades are a little long as i now have a cut through the hull to fix. pics after day onebaot4a.jpgboat4.jpg
fishmonster13
going to keep a list of money as well as materials for the project
so far
boat $400
trailer light plug $5
bearing buddies $12
trailer jack $25
winch $25
total $467
goiiing to sell the motor that came with the boat and put that towards the purchase of a new used outbaord
fishmonster13
still havent decided on a layout yet, but i did get a little more done today, installed new winch, new trailer jack and adjusted a keel roller so the boat sits on the bunks, properly and did a little more tear downphoto 2 (2).jpgphoto 3.jpg
fishmonster13
got a little more done today finished cutting out the livewells, removed transom and started grinding , still have at least one more day of grinding and sanding before i start laying new glass1517651_796507547031113_2143212056_n.jpg1532118_796507473697787_555871562_n.jpg
jbcurt00
The bench you removed probably offered some support across the width of the hull for the gunwales, as did the live wells & deck you removed at the bow. And there probably was a good bit of flotation foam in the structures your removed as well.
What's under that center section that covers the keel:
attachment.php
What's the plan for put back of the support & foam?
You made quick work of the clean out so far. Make sure the boat hull hasn't moved or flexed after removing the interior.
Woodonglass
Yeah, I agree with JBC!!! Hopefully you took a bunch of measurements before you did all the demo so you can ensure the hull goes back to relatively the same configuration she was in the beginning. If not the way she performs on the water can suffer. The Seats in the boat provided all the support for the sides of the hull so you'll for sure need to do some serious re-engineering on that to ensure she is structurally sound from that aspect. How is the boat going to be utilized? What kind of water will she be on? These little glass tri-hulls are pretty flimsy and you might need to consider laying some additional glass to stiffen up the hull or maybe not. Your Call. 25 hp fishing boat may not be needed. Are you going to put foam back in?
fishmonster13
i got plenty of measurements, the center section is open underneath going to se it to run wiring and such, back is going to be a deck with foam in the corners, no livewells but will brace where they went and the front will be about the same
fishmonster13
well, hadnt had a chance to do much on this boat until the last couple of weeks, finished with the grinding and now in process of building it. got the bulkheads glassed in, transom is in, started to foam and ran out of foam, so i flipped it and started to sand and do the repairs on the bottom.
fishmonster13
No Title
bottom is done and boat is flipped back over and ready to finish the interior once the foam arrives, i did pick up a motor for it this week, found an 86 evinrude 25hp tiller in great shape and ordered some deck hatches today to put in the rear deck
fishmonster13
No Title
heres a few photos, got a little more done today finished foaming under the front deck and installed the transom bracing, filled small holes in transom and a few other spots
fishmonster13
No Title
fishmonster13
it did turnout nice, unfortunately i already have twofootitis, but it will be a long time before i do another glasser
