Hello All!!
First like to say this forum is amazing! So much knowledge out there, it has been a real help.
I'm hoping to get a little advice on my stringer and transom rebuild on an 88 Sea Ray Seville. I am no stranger to the composite world but boats are all new to me. This is my first boat so please bare with me if these are redundant question that has been answered many times before.
I have started the removal of the deck on my boat to assess how badly rotted the stringers are. Long story short I have to replace the stringers about 3/4 of the way up the hull and looks like the transom is on its way out. But now the cold weather appears to have caught up with me and its going to be to cold for me to glass in my drive-way now. So the company I work for has been gracious enough to let me use the shop for glassing since the shop is heated. But I cannot leave the boat there, so I was planning to bring the boat in step by step as I progressed.
My plan was to remove the rotted stringers and transom. Build the new transom and then take the boat to work to bond it in. Then bring it home and fit up the stringers and return to work and bond in the stringers and so on until the deck and all was completed.
I'm worried that because the temperature is dropping and only being able to work on the boat on weekends that transporting the hull on the roller trailer might leave me with some issues. I though about placing 3/4" plywood across the rollers to help disperse the load and relieve some of the pressure points.
So my questions to you are:
1) Can I even transport the hull with the stringers and transom removed?
2) Will transporting the hull in between bonding steps cause me problems down the road with the hull flexing?
3) Should I try blocking the hull on the trailer to better support it?
Any suggestion would be greatly appreciated! Also I should add waiting till spring is not an option:grumpy:
I have attached a few pic of the current state of the floor and the rollers on the trailer.
