boater1234
Master Chief Petty Officer
- Jan 6, 2010
- 869
I'm going to apply this to the bottom of my boat to fill in pitts.Here is the question i have.I know it says to wipe area down with acetone before use,after you apply the acetone and it dries do i just apply the 5200 right after or do i wash it down one more time with freshwater and then let it dry and then apply?
It says don't use any alcohol because it won't cure so thats out.After the 5200 cures can it be sanded?What i want to do is put a nice skim coat on the bottom of the boat and then sand it smooth,painting it is out because the 5200 flexes and from what ive read will just crack off the area of the 5200.
I'm just going to add a zinc anode to the bottom of the boat and that should take care of anymore pitting from what i read,is this right?Also what size anode would i need for a 1436 jon boat?
