Re: Fiberglass Restoration project
Hi and welcome to the dry dock, 2face...
Couple of things...
Can't tell for sure, but your boat seems to be constructed similar to a Boston Whaler...in other words...two fiberglass sections, upper and lower, held together by expanding foam...in one of the pics, there is a hatch opening...try and take a good pic of the interior of that and see if the void below is filled with foam...
If it is this type of construction, there are certain ways you need to go about separating the upper half [aka the "cap"] from the lower half [aka the "hull"]...
If the rub rail is what is actually holding the two halves together, then you have a regular type of construction, which is a bit easier to separate from each other...
The other thing is, in your photobucket account, when you click on a picture to view it...along the right hand side, there are several codes to choose from...
Left click on the box that has "IMG" next to it, and it will briefly turn Yellow and say, "Copied"...
Then return here to your post and paste that code...
At first it will look like a bunch of letters and numbers...
Below and to the right of your post, there is a box that says "Preview Post"...click it and you can see the image...
When you do that, your pics will look like this...
Best of luck and looking forward to how your better than new boat is gonna turn out...
Have Fun1
GT1M
