Can someone please suggest a thru-hull petcock valve that can be used for emptying holding tank waste? I can boat 3 miles off-shore and therefore a candidate for emptying a holding tank into the ocean. My main question is: Would a clamshell petcock valve work for this waste removal or would it be subject to clogging up (I do have a macerator pump with the holding tank).? Lastly, where on the hull is the ideal spot to put the waste thru-hull? I assume under the waterline on the side? ? the previous owner keep the holding tank on the swim grid which I am not a fan of ... nor are my fellow moorage neighbours!
Thanks in advance for any insight you can offer
