Joel_CA
- Sep 14, 2013
- 16
I was cleaning out my boat and emptied out the in-floor ski locker to wipe it down. Lining the bottom of the ski locker is factory snap in carpet. Upon removing the snap in carpet, i noticed a water stain (now completely dry) that was coming from a small spider web crack at the port side of the ski locker well forward of where the lid is. I have no idea how water got behind the locker tub- but i want to be able to dry it out or remove it if there is any standing water there. I contacted SeaRay customer service, give them my HIN and asked how i would be able to remove or dry out any standing water from that area and that if there was any standing water in that area, does it would spell trouble in the future. I asked about the boats construction, how water could have gotten there, and if the stringers were at risk from any water getting behind the locker.
To this they replied " We don't have a brochure showing the construction of the boat but I can tell you that this boat has a fiberglass Liner instead of Stringers. It also is foam filled under the Liner for floatation.
The only wood would be in the center of the Transom , bilge for support of the Engine, and anywhere else that needs extra support like behind cleats & seats". "If water is in this area, there isn't any other way to get it out than to drill a hole to let it drain out. We would suggest having a surveyor take a look at the boat to determine how much water it may have in it. With this being foam filled, the foam should dry out once the water has been drained."
The ski locker itself has an aft drain tube the routes under the fuel tank and into the floor of the bilge. With this being the case, that would mean any water under the ski locker or under the fiberglass liner would have no way of draining out as the bilge appears to be part of the fiberglass liner. There are plastic plugs at each side of the ski locker that i removed to check behind it. Behind it is foam- all the way up to the plug hole. The foam feels dry. I tried lowering the front of the boat so the bow is down- to see if i can get any water underneath to come forward to seep out of the crack. I left it in that position for at least 12 hours and didn't get a thing out of it. Should i just leave this alone or should i actually drill a hole where the crack is to see if there's anything back there?
