banshee owner
- Sep 4, 2013
- 227
Hello
First post here so here goes i have 1975 vangaurd banshee and found out transom is at least partially if not all rotten. Someone before me has attemped a repair by way of steel plate on the back up over the top and into part of the splash well. I am going to attempt to rebuild it this winter. My plan is separate the top to gain open access to the transom. I have been doing a ton of reading so much so that my head is spinning. i pretty well know im going to need marine grade plywood the only boat supply place near me is a place called noahs marine supply they have meranti plywood. so my questions are:
Is meranti the right type to use? Meranti : Noahsmarine.com Im looking at the bottom listing only because it seems to be the cheapest but is it right. I think 18 mm is the way to go ans doubling it up ect.
Second question is i dont think my transom is that big so will the left over plywood be suitable for stringers(depending of course if there enough.)or should i use something different for stringers.
Third question is am i out to lunch on fiberglass. Im thinking of using economy fiberglass cloth(seems to be cheaper with minor flaws Economy Fiberglass Cloth : Noahsmarine.com
im looking at the top listing because it is again cheaper but is it right. The listing doesnt really say anything about strenght ect. If i should use another type then it is what it is. Some sort of direction in this would be much appreciated.The problem i have with fiberglass is everything i read says use biaxle and csm and listings on the site refer to mat and cloth and im not sure which type means the same. biaxle is actuallt mat or cloth.
im still up in the air about resin and have to price compare but if anyone could ring in about it i would be easily convinced.
i know this project is going to take alot of time which isnt really a hugh issue money savings is kinda important but on the other hand i dont want to compromise integrity buy using the wrong stuff.
I currently dont have the boat home to take pics and post but i will be bringing it home and im sure i will have many many more questions. i have found this site a excellent source of info and helps set my mind at ease as to how to do repairs. AT first i was ready to scrap the boat or pay someone then i found out just the cost would be too much. Im at the point now that i have come to accept that thee is a possibility of ruining the boat. I dont want to but if i do then i have some decisions to make. i love the look of the boat and it performed extremly well on the water and the kids had a blast on the tube.
