I have a '88 Nitro F/S
One of the previous owners decided he didn't need use of the livewell so it was disconnected and the switch is gone
I wasn't sure the pump would even work so today I connected it directly to the battery and it whirred to life. Hurray!
There are four holes in the transom that I wasn't sure which was which but I think I have that figured out now but would like verification
I believe the holes are as follows (see pic)
1. livewell intake
2. bilge drain
3. livewell drain (definitely is because I filled the livewell and it drained out that one...see pic)
4. This one has a hose attached that I think runs to the bow
So my question here is, if I want to use the livewell, do I leave holes 1 and 3 unplugged? Is that how the water circulates?
Also, on the intake (see pic), something was hack-sawed off for some reason, I'm guessing it may have been a screen. Any suggestions for how to attach another screen?
On to the the livewell itself (see the pic for what it looks like inside and yes I'm going to clean it!)
Am I missing pieces?
I would only be able to fill the well less than halfway the way it is.
Is there an extension i could put on the overflow pipe or would I have to replace the whole pipe?
Also, what's to keep the water from draining when the boat's in motion? Wouldn't the lower drain hole need to be plugged? Or do you just leave the pump on and let it continuously circulate
I know that's a lot of questions so thanks for help on any of them
1. livewell intake
2. bilge drain
