Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
homemade 2 man pontoon boat quest
  • homemade 2 man pontoon boat quest
    I am a collelege student so i am on a budget , but i want a small little boat to fish the college lakes with. I have been looking at those small two person plastic boats and they seem pretty cool but are really expensive. So i decided that I would build me a miniture pontoon boat. Has any of you done this before? I was going to use two ten or twelve inch pvc pipes 6 or eight feet long and filled wiht stryofoam and 4feet apart. Is this a good guess? will it hold up me and a friend (total of maybe 600 max) I want the rig to be as light as possible so i can unload it my self. Do i have the right idea? how would i mount the deck any ideas on how to make the deck. I am pretty good with tools so i am confident i can build it, i was just wondering if anyone has done it before and would like to give me a few ideas. oh and theres only 3 weeks till school so i gotta hurry. thanksD
    Re: homemade 2 man pontoon boat quest
    Scrap the PVC idea, way too brittle and the diameter too small.Two direction you can go - 1. Do as I did as a teenager, strap treated pine decking onto toons made from 44gal drums. Weld the drums together. 2. Buy aluminum toons and build a floor ontop - just like a house - bearers and joists. The toons should come with mounting points for the bearers - use a large bearer at the rear to mount a small outboard or elec kicker.Aldo
    Watch this space......................
    • #3
      Perhaps you could lengthen this fine design.
      • #4
        back in the "old" days, we used tip tanks/fuel tanks from salvaged jet fighters and bolted them togather beneath a platform. Got some streamlining and a little more length.
        • #5
          Alden that thing looks like fun. Any idea what that thing is using for floats?
          • #6
            Looks to be a foam insulation board. Check link http://www.owenscorning.com/around/i...s/foamular.asp
            • #7
              HEY that's my lawn chair, you better give it back or I telling mom
              • #8
                Here is a site with a free set of small pontoon boat plans. The designer is very helpful and reputable. JEM Watercraft Pontoon boat plans
                • #9
                  Eye theenk u mint tu saay "college" not collelege. I think that the pvc would work just fine,and it would be cheap and easy to do make.I have read about others wanting to do it,just have not seen the results.As for being brittle,I cant imagine that anything you would run into at the speed you would be going could put a hole in it.Think about it being buried in the ground with a whole lot of rocks and dirt on top of it.And for the diameter being to small,as long as it floats 10 or 12 inches would be fine.I have seen some "factory made" 10' pontoons and those are not any bigger than 10 or 12 inches. http://www.ourfamily.com.sg/olsen.html
                  • #10
                    Is there any formula or way of calculating how much flotation a 12"x 10' pipe of pvc would provide?
                    • #11
                      hang on, have to figger this one out
                      • #12
                        12"X 10' X 2 = Swimming.
                        • #13
                          A very rough guide is - I sq metre of encapsulated air will support 1000 kg. That will place the top of the toon at water level, to have the toon half in - half out, you need 2 sq metres of encapsulated air.12" diameter just ain't gunna do it.
                          • #14
                            I'll bet you could buy an old jon boat or skiff for less than what you'll spend making something.
                            • #15
                              pi times radius squared times length ....3.14 x (.5 x .5) x 10 = 7.85 square feet of water displacedwhazzat mean?7.5 pounds of water in every square foot of water, therefore 58.9 pounds of weight would submerge the pontoonyou want to have the pontoon at half depth so judge the capacity of the craft on ONE pontoon, that will give you both pontoons at half depthdiameter is the biggie here, bumping to a two foot diameter tube gives FOUR times the volume, easily supporting a two hundred pound fishermanA three foot wide, 12 feet long tube would displace 84 3/4 feet, or 635 pounds of water, two would carry two good sized guys an outboard and ice chest.Im no good at math, I may have screwed this up, tell me if Im off base, but as usual I think im right
