I have a 17ft tri-hull Sirocco fishing boat I am working to restore. It spent a year in a salt water wetslipe with no cover and another year in a yard with no cover (I know Im an awful negective boat owner). At stern there is a piece of plywood the previous owner used to replace the front casting deck when the fiberglass and fishing chair started breaking through the floor.
I started restoring the boat and pulled up the plywood and found rotted plywood all over the front of the boat. The rotte d wood looks like 1/2 inch plywood and it is supporting the raised fiberglass floor. It is rotted in the casting deck area as well as the first couple feet of the lower floor.
I only see one stringer which is coated in fiberglass and goes down the center of the boat and seems solid.
I dont want my boat to rot away, so i need some tips on how to handle this floor rot. Im debating on cutting out the whole casting deck and the 2 ft of lower floor and replacing it all with a larger front casting deck but i dont know
How far the lower floor has rotted
or
how to fiberglass new replaced wood
or
how to attach a section of new wood to the old wood thats not rotted...etc.
Also, the steering cable is siezed up. Any suggestions other than pb buster and beat itwith a hammer?
or
or
