West system says that the epoxy will reach a "green state" or Gel state after pot life but before final cure. It says that you can reapply once it's in this state and it will chemically bond with the first coat. The longer into the gel state the less effective the chemical bond will be. <br /><br />They provide a graph of the cure times, but the graph has no units on it.<br /><br />If I'm using 5:1 fast, i think they call it the 105 hardener:<br />-when does the gel state start?<br />after the 20 min pot life?<br />after one or two hours?<br /><br />They describe the gel state as being like hard rubber. No longer tacky but you could dent it with your fingernail.
