I recently purchased a 1985 Bayliner Capri Cuddy Cabin boat. I am actively using the boat this summer and fixing things on the boat as I go. I figured this is the place to ask about boat repairs and stuff like that. This is the first boat I have owned although not the first boat I have used. I had a buddy who used to store his boat at my house and I would take it out when ever I want. This is the first boat that I am responsible for the maintenance and repairs on.
When I bought the boat a few weeks ago, I looked it over and missed several things that may have swayed me away from buying the boat. The boat does work well in the water and I am mostly happy with its performance but a minor issue here and a minor issue there seem t add up. I seeing a few red flags that I kinda wished I had noticed during the initial inspection. Anyway, I own the boat now so minor repairs for now and possibly more in depth repairs will take place in the winter when the weather is cool enough to go outside and spend time working on the boat.
The minor issues that I recently noticed are the bumper strip around the hull cap is pulled up and has gaps you can see from underneath. There is clear silicone at parts under the bumper strip. It looks like it is riveted on? Some of the Rivits are pulled out. Nothing is loose but there are some significant gaps you can feel if you run your hand under the rub rail.
Another issue I have found is the wall that separates the cabin with the steering wheel and dashboard mount seems to have been removed and installed in kind of a cheep way. Large bolt heads go through the wall and into the seat sides in the cuddy. The Dashboard panel looks crappy. I do not know how else to describe it. I will post pictures.
I realize this is an 80s era Bayliner and floor rot is a concern. When I went and looked at it at the guys house before the lake test, I did not find any soft spots in the floor. The bilge seems clean. Tapping on the transom with a screwdriver handle.(it was all I had at the time) did not reveal anything. After I got it home, I started to think about it. The carpet had been replaced and I started wondering if it was hiding a floor that had been repaired. I do plan to be on the lake as often as I can this year so I was a bit afraid to look to hard. I did peal up the corners in the back and the floor looks original. Unfortunately, I did find a small soft spot in the floor in front of the seat that I on the side of the swim deck.
So while I know there is much more coming, my first question is, what is the process for replacing the rub rail around the outside of the hull? Do you buy a new rub rail kit or do you try to reattach the one that is there?
