Re: Spraying Awlgrip paint
Spoke to Awlgrip representative.<br />They say "Tyvek" painting suit, OV respirator, gloves are a must. <br />I think it is not that bad if it is done outside, as the vapors will disolve in the air. Awlgrip may not bond to other paints, so they have suggested to use their primer. I don't feel like finding out the hard way, so I will use primer. <br />Primer needs it's own "converter" and "reducer" that is different from the one used with the Topcoat. <br />As I said I will be using a professional spray system. I am not sure if electric gun will provide as much of the flow as you need for this application. I sprayed "Interlux" using electric spray gun. That is the same surface that I will now paint with Awlgrip. Electric gun is not my thing. Rather then placing a nice amount of paint evenly spread, as most of the high priced guns do, electric spray gun "Wagner" was spraying an uneven mist of paint. Another thing is, with a pro gun, there is an option where you could blow air to the surface, which will dry paint if you suspect that a "run" is possible. Not available with electric gun. Bottom line, after spraying "Interlux" with electric gun I decided to go ahead and paint with "Awlgrip". I sanded all "Interlux" down to the original paint. <br />Besides health concern, Awlgrip is much more expensive. It will run around $200 and change for the total of 6 items: (quart of each)<br />Top coat, reducer and converter<br />Primer, reducer and converter <br /><br />HERE IS THE HEALTH RELATED CONCERN - <br />Isocyanates:<br />"Health effects of isocyanate exposure include irritation of skin and mucous membranes, chest tightness, and difficult breathing. Isocyanates are classified as potential human carcinogens and are known to cause cancer in animals. The main effects of overexposure are occupational asthma and other lung problems, as well as irritation of the eyes, nose, throat, and skin".<br /><br />My choice - Awlgrip. I do not see how brush and tip method is any safer then spraying.
