Re: 1990 galaxie california deck repair help
New transom piece is complete. here is what I did, I sandwiched two pieces of 3/4'' marine grade ply with 1 oz csm, I used (resign (polyester non waxed) on both pieces then wet out csm then used wood screws to clamp together (pilot holes drilled larger then scew in top piece). After everthing hardened I cut off all the excecess with my skill saw then belt sander to smooth everthing then lastely I grinded down the screws on the back side. I plan to just leave the screws in.
I will next coat the entire thing in resign.
so now im ready to put the transom in the boat. Should I use a layer of csm between the transom and the hull?
I saw that woodonglass did a layer of csm on both sides then tore the extra off and then pushed the hairs down I got a little confused as to weather he did that then clamped it in the boat or what.
Im going to keep looking around but if someone has a quick answer for me that would be great.
I almost forgot, so my boat has a single stringer then forks into two doubling as the "motor mount stringers", these stringers where originally glassed with the transom. I feel like it would be better to glass the transom then glass the engine mount stringers to that so that way every thing is separated from each other. what do you all think?
New transom before being trimmed.
