I have a 1977 Skipjack 24 Cuddy powered by a 351 Ford. 280 outdrive with the "spinning pin wheel" drive. Not sure of the correct name.
Boat runs. Still uses seawater to cool, which I where I use it most.
Questions:
If I was to repower the boat and put a new outdrive on it, which is the best option to go with? (Gasoline engine)
Second question. The exterior is starting to crack around the upper platforms, cabin roof and cockpit exterior....solution?
Thanks
NorCal Allsvsn
Questions:
Thanks
NorCal Allsvsn
