I read a post about someone making a removable hard top and it got my mind thinking, now I got some questions. I plan on making a hard top for my aquasport this off season. I want to make it like the hard tops many manufacturers are putting on their ~23 fishing boats. Aluminum tube frame with a rigid hard top w/ rod storage and attenae mounts. <br /><br />Anyway I was planning on using ply and glassing it over, but weight is definetly an issue. So I am thikning glassing over foam would be not to difficult and weight a bunch less. <br /><br />So I want to lay fiberglass mat down with epoxy resin over the foam top. I was thinking of just using the ridgid insulation the lumber yards sell.<br /><br />What foam will epoxy resin not kill? I have teh traditional ridgid foam foil faced RMAX type insulation readily accesible, and can get my hands on a similar product called foamular with is similar but blue or pink in color and seems more elastic and "plastic-y".<br /><br />Which will work? I would rather use epoxy based resin but if nessecary I could use polyester resin?<br /><br />Give me your input,<br /><br />Thanks very much<br /><br />TOny
