Re: Question about stainless steel screws
I am getting ready to assemble my boat interior - I always have a problem with stainless steel screws stripping out easily? Is it just me? I buy them from the local hardware, but wondered if I should be looking at a harder steel if such a thing exist.
Thanks for your help
Here is a Tip for the SS screws .. Pilot with the proper bit.
If its too hard to put in by hand on the first screw .. then you have too small of a pilot.
If the screw is getting Very hard to put in .. take it back out and trash that screw and replace with a new one. Dont Ever reuse SS screws .. you might pull the head off !
Once you get your proper pilot your good to go with a screw gun. The impact guns work the best ( with a good quality Tip ).
If your going into alum. then take one size larger bit to pilot. Alum will heat up the screw fast and break often.
If your going through 2 surfaces ( like a hull/deck joint ) .. over drill the first surface so the screw only gets screwed to the last surface..
YD.
Edit: PS ... if your talking threaded bolts .. if they get hot then trash them. They can Melt to the nut and create problems down the line. FYI.
