Have You Built or Installed a Marine Head?
Have any of you all installed a marine head in a boat that did not previously have one? I am sort of in the planning stage of putting one in our boat. We have a porta potti that is stored in the cabin and while it has seen relatively little use (we follow the old rule that ladies go inside and, with prudence and such decorum as possible under the circumstance, guys go over the side) over the years I was just getting to where a built in unit looked like a good idea. I saw a very interesting picture of one in a magazine (Go Boating, October 2004, p.51) in an article about the WellCraft 252 Coastal.<br /><br />In the pictured arrangement the V-berth has been cut out and a head installed below its height. A hinged lid comes down to cover the cutout box into which the head is mounted and the lid has a chushion on its top to match and become a part of the V-berth when it is down. A very neat way to make use of space and at the same time give a much more stable platform for the head than the porta potti that we have now. So I thought I might try to build in a similar unit in our boat this winter.<br /><br />The thing is I don't know anything at all about marine heads and the plumbing end of it all. I don't know what sized tank would be appropriate, what size lines, what part has to be higher or lower than what other part, should I go ahead and spend the additional money for an electric unit (the money is not really a problem but I would like to keep costs under control), what about water intakes, can it operate off my current fresh water tank, how much water does it use? Can you rig up an overboard drain (we operate far off shore much of the time) to expell waste where leagal and appropriate or do you just use a holding tank? What about pump out, how does that work? Where do you do it or get it done? How bad a job is it (remember, you are telling this to the Official Dumper of the Porta Potti)?<br /><br />I really don't know anything at all about this and could use any and all advice and hints.<br /><br />Thom
