Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
Sunbird 1991
  • Sunbird 1991
    Hi Everybody!!I recently traded my boat for a 1991 Sunbird 21 footer Center Console with a 1992 150 HP Johnson. It all seems to be okay (motor has 75PSI compression even in all pistons). The wiring however is a mess. Under the console the wires are a mess and so are they in the back. I am very handy and think that I can arrange the cables and fix nicely. Does anybody have any advices before I jump in? Can I buy a new harness? Is there a way to find the wiring diagram for this boat/engine?Thank you all in advance!
    Re: Sunbird 1991
    You can order a manual from iboats.Is the engine running now?I believe you are about 25 pounds short on compression. And put back the right color wires if you rewire it.
    • #3
      Re: Sunbird 1991
      I was told by a mechanic that 75psi (even on all pistons) is acceptable. The motor runs very strong. It does about 55mph with no problem.Thanks.
