Re: Marinette 28'
As I recal Marinettes are welded Aluminum hulls.<br /><br />I've lusted after a 'deal' on one like you're looking at for 20 years.<br /><br />However:<br /><br />Until you can test run it---<br /><br />The hull probably has about 1000 pounds of Aluminum in it. That should bring about 50 cents a pound at the re-cycling center.<br /><br /><br />If the engines aren't blown apart from freezing, or just worn out,,, the core deposit on their blocks and heads are probably worth about $500. total. <br /><br />If you have to buy it 'as is'. Its a salvage deal where you don't get paid to 'make it dissappear. The salvage on it 'as is' is about $1000. Maybe the owner can find someone to pay more, but the field is very narrow in that reguard. <br /><br /><br />If and when you can drive it across the lake---- of course the price goes WAY!! up. Then you get into how good the paint job is, and what the upholstery looks like. In that case, you should be able to seperate the owner from it for about $7500 or so if it looks good and runs good even without a trailer.
