1954 Lone Star Commander
The13thSon
Just some pictures of my restoration of my 1954 Lone Star Commander I bought from my neighbor in 2012.
The13thSon
Re: 1954 Lone Star Commander
The Trailer
The13thSon
Pictures of the paint being removed from the exterior. The bottom of the boat was very pitted and I filled that with Gluvit and J.B. Weld. I’ve been on the water about 24 times and its worked perfectly.
iPhone 6-4-2013 535.jpgiPhone 6-4-2013 536.jpgiPhone 6-4-2013 537.jpgiPhone 6-4-2013 538.jpg
The13thSon
Primer on the top and bottom. All of it was painted with self-etching Rustoleum primer. I then used a light grey primer over that on the top section because of the final color I was going to use.
The13thSon
Here it is with the silver upper complete (not buffed out yet) and the new Lone Star decals applied.
The13thSon
Here is the black Rustoleum marine grade bottom paint (under the water line). Also used Hurculiner on the transom motor mount section.
iPhone 6-4-2013 581.jpgiPhone 6-4-2013 582.jpgiPhone 6-4-2013 583.jpgiPhone 6-4-2013 584.jpg
The13thSon
Masked it up to apply 3M 5200 black and mixed my own gray for the above water areas, as well as using the white around the upper area
Woodonglass
Very Nice. Looks like good attention to detail! I like it!!!:D
The13thSon
More to come, I need to reduce the size of the pictures from this point. I complete the Interior with Tuff Coat floor paint, add a drain hole, rebuild the transom and add an Anchor Mate. I also cut out the rear seat to add a compartment for 2 batteries and an onboard Minn-Kota charging system. I’ve added Interior and exterior lighting complete with a control panel and a lot more. I am beginning a restoration of a 1963 Mercury Merc 60 6hp as well to add to the boat. Here she is behind the FJ.
Woodonglass
Did you do any reinforcing to compensate for the removal of the rear seat? Have you added or considered adding any flotation foam?
The13thSon
Transom being replaced, I actually had to cut the supports on each side with a cut off wheel. You can see it was very rotted out form being stored for many years upside down.
The13thSon
Tuff Coat grey flooring in, new paint, Anchor Mate, new transom with new aluminum diamond plate supports, new seats, and drain hole.
The13thSon
Interior lighting and control panel (I am remaking this control panel, I’m unhappy with it)
The13thSon
"Did you do any reinforcing to compensate for the removal of the rear seat? Have you added or considered adding any flotation foam? "
I have not taken any pictures of this yet. I will tonight and post them. I've had her on the water twice sense I modified it. I believe the way I cut it, it is very close to as strong as it was before. As far as floating and foam, it was a concern of mine but I just went for it one day. Hope not to regret it but I get the feeling it’s going to be ok. The boat is extremely stable even in bad weather and strong wind, I still have the other two float chambers lol.
