Re: clean hull with?
Look thru his other threads about this boat
The question was more for his info then mine, but unless I missed it, the fairing step hadn't been listed previously, here. Although, as I understand gelcoat (which ain't much) gelcoat cracking is tough to deal w/ and a bear to try & keep from telegraphing thru new coatings applied over them.
Esp since previously, the gelcoat was described more as CRACKING, not crazing, which tends to be less problematic.
Then add the metal flake already being exposed & rough, sounded like it's already at or past the 'not too much flake exposed' point.
Boat is a 1995 Ranger R70. Worn down to the metal flake and 17 foot long. Here is a sample of what I got for a finish now. Cracked all the way down to base coat
Based on this ^^ and the other 2 or 3 threads w/ discussions about this boat, its metal flake & painting it, it looks & sounds to me like much more is likely needed then through (but not too aggressive (?
?)) sanding, paint prep, primer, paint prep & paint....
But I could be wrong.
I am not doubting your advice about painting or the tips you've posted. Seems to be all good stuff
