Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
Repair of ABS plastic boat
  • Repair of ABS plastic boat
    I have an old two man bass boat, an Outlaw, which has several cracks in the floor. I have looked for a good way to repair these cracks but not found any suggestions. Because of the way I use this boat appearence is not a factor. One is a particular problem because it is right at one of the corners. Water inside the hull of the boat is a problem because there is no drain.
    Re: Repair of ABS plastic boat
    You better get them fixed or they'll end up like the Sooner defense, once they expose a crack, everone comes flooding on thru!! Go Huskers!!
    • #3
      Check with a Chevrolet dealer that has a body shop or a Saturn dealer. The body panels used on the old Lumina APV vans and saturns use plastic body panels. There is a way to "weld" and repair them. At least it will be a good place to start.Bob
      This is a great link to boat specifications http://boatspecs.iboats.com/
      Please, shop iboats first!!
      • #4
        maybe better yet, call ocean kayak, or perception kayak. they make sit-on-top kayaks from roto-molded plastic. they can probably tell you how to make a repair.
        • #5
          Is it like a Buster boat? When that plastic gets old it gets brittle. The urethane glue used on body panel repair isn't gonna stop new cracks. I'd get a gallon of epoxy and smear it over some fiberglass CLOTH. Don't use matting use some fine woven cloth. Just cover the whole thing with a layer of epoxy and cloth then it'll be better than new without adding much weight.
          • #6
            Originally posted by Quantumleap: You better get them fixed or they'll end up like the Sooner defense, once they expose a crack, everone comes flooding on thru!! Go Huskers!!
            It looks like your team will be in Norman this year. I think that the OU Nebraska rivalry is one of the best, and like the Nebraska fans. Lincoln is a rather inhospitable winter venue, but you guys can't do anything about the weather! Do you have any advice as to the best way to fix my boat?
            • #7
              any collision repair shop that is up to date on equipment will have a plastic welder. I use one all the time for bumper repair on todays carsJohn
              • #8
                Thank you bob and cut n' jump. The Chevrolet dealer sends all their body stuff out so I am making some calls to the body shops they use. Yes, it is like a bass buster boat. It has had a lot of exposure to the sun and the top half has become very brittle. If I can't find someone with a plastic welder, the fiber glass repair sounds like something I might be able to do myself. Thanks to all for the input
                • #9
                  I thought I saw a plastic repair kit through Eastwood or JC whitney or something like that. The key is getting it to seal up properly.I'll probably be eating my hat come Nov. in Norman! Stoops has done a remarkable job in turning that program around and the addition of Pelini will only make them better. I'm hoping for similar results with the new Callahan staff. Talk about having your whole world turned upside down. I'v been a fan since I could talk and it was like losing a family member seeing all the Husker tradition go out the window, but I'll admit something had to be done. You can't be that predictable anymore. Good luck on you plastic repair, Let us know how it turns out.
                  • #10
                    I have one of those boats. I used an epoxy to repair the bottom of it about 3 years ago and it hasn't leaked since.
                    • #11
                      I don't know if you're still working on this project, but Harbor Freight sells plastic welding kits.
                      -BWR
                      http://search.harborfreight.com/cpis...d=plastic+weld
                      1976 Starcraft Kingfisher Frugal Functional Fix-up
                      1976 Starcraft Chieftain 18' OB - restomod
                      1985 Mercury 50HP 2-Stroke 4-Cylinder
                      There is a fine line between stoic... and stupid.
                      • #12
                        I repaired a Bass Hunter plastic boat that had a crack on the hull located on a curve and at a groove. It worked very well and was very easy. I called the company and ordered their repair kit for $15 or so. The number is 800-345-4689 or go to basshunter.com. Hope this helps everyone.
                        I have a question. Has anyone filled this type of boat with foam insulation? Did it work? Thanks for any help.
                        • #13
                          I repaired a Mohawk canoe made from ABS using West System epoxy and
                          fiberglass cloth. This repair came out well. The West System web site describes
                          the process.
                          http://www.westsystem.com/ss/molded-...-boat-repairs/.
                          I finished the process with Krylon Fusion. It's not the most durable finish but
                          it got the boat back to all one color. Touch up is easy and cheap.
                          Good luck, GH
                          http://www.urethanesupply.com/ Good site for plastic repair products.
                          • #14
                            the process.
                            Good luck, GH
                            WOW, anyone look at dates???? prior to 1 post Jan of this year the thread was from 2004
                            Bill
                            "I'm not young enough to know everything"
                            My Project
                            1973 21' Cruiser Restore
                            The Resurrection of the SeaGem
                            The Hijack Zone - Zombies Welcome
                            • #15
                              I replied to a post dated 10/21/09. There might be someone out there now working on an ABS boat who could use the information in this thread. I wonder
                              why my post was quoted. I wonder why you replied at all when you had nothing to contribute.GH
