StickyHooks
- May 20, 2013
- 11
Hello iBoats,
Thought I'd document my first boat build after lurking on the site for years gathering information from the community. I am the proud owner of a POS 18' Starcraft Holiday that has left me stranded on multiple occasions. I think I've tied a rope to my waist and swam this boat back to share 3 times now, once with my fat cousin sitting on the bow refusing to paddle. Many other breakdowns include bouncing off $50,000 boats in the river trying to get back to the launch on busy holiday weekends, embarrassing.
Time for a gut and build project.
I will be converting to an outboard so a new transom design is in order. I've read every forum post possible on material selection but after looking at the rotted junk that came out I'm not going to be too picky. Starcraft only painted the transom wood from the factory and relied on epoxy to seal it on the 'backside'.
My choice was (2) 3/4" and (1) 1/2" chunks of plywood for a total of 2" thickness, coupled with a piece of 1/8" angle iron to cap it with. I wanted ACX but it wasn't in stock so BCX got thrown in the truck.
I measured my motor to confirm it was a 20" shaft and then decided to mount it a 21" to live on the edge a bit. Found a piece of cardboard to use as a template and cut it to size, then transferred the cardboard pattern to the plywood
After cutting into the BCX I noticed the interior voids were not filled/sanded like I had thought. Oh well, thats why I ordered extra epoxy from US Composites. No complaints so far.
After a bit of sticky work I had a drop in transom assembly. I used exterior grade scres to clamp the sheets together. I also paid very close attention to the edges of the transom as it soaked up more epoxy, this took 3 coats before I was confident in it's water resistance.
I then referenced Glen L Marine's manuals for the final outboard well dimensions and cut the entire transom to size using a circular saw (set at proper depth to not hit the aluminum sheet) and a sawzall for the aluminum portion. It is not beautiful but it is tough as nails. After letting it cure for 24hrs I mixed another batch of epoxy and really laid it on thick over the exposed top. Then I laid the channel iron and set the motor.
Tonight I will align and bolt the motor (150hp Black Max), looking at the install height I'm really happy I went with 21"
Future plans include:
-Outboard Well made from left over angle iron and plywood
-100% wooden gunwales made from Cedar and Red Oak (I know Red Oak is not ideal....)
-Aluminum Gas tank install, 8cu*ft of closed cell foam in the floor
-100% Wood Floor, T&G Pine slathered with epoxy and some beach sand
-90% wooden Center Console made from Cedar with a canvas t-top using conduit and marine canvas
-This was going to be made from bent exhaust piping but the steel would interfere with my autopilot compass
-100% Electric Steering with compass autopilot, using a controller and a ballscrew linear actuator
Stay tuned, this should be fun. Please comment and post as you'd like. Heres the budget so far:View attachment https___docs.google.com_spreadsheet_fm_id=tz4Co-kWPh3XY1nXrTqPHZw.03253096254560060448.pdf
