Badfish95
- Jun 30, 2012
- 118
This question was asked in my build thread, but I thought this may cast a broader net.
I'm looking for some opinions on using Peal and Seal inside the engine compartment. Originally, the boat had a foil faced sound deadener/thermal barrier on the insides of the vertical deck lid supports. I would say the panels are 6-8" away from the engine. It looked to be a butyl rubber/ asphalt mat with foil facing. It was heavily stapled onto the panels. Lowes sells Peal and seal(for roofing applications) for $17.00 for 6"x25' roll. That is extremely cheap compared to the name brand sound/heat deadeners. Do you think peal and seal would work for this application?
Foil faced heat insulation?
This shows approximate distance from the engine.
