I need to restore my captain's chair seatpost base to the fiberglass deck of my boat. A previous owner had mounted the round base to a slightly larger 3/4" thick piece of plywood and then secured that to the deck with ss sheet metal screws and what appears to be epoxy. It rotted and basically failed. After removing the leftover residue via cutting/grinding, the fiberglass deck seems to be pretty sound in the immediate area under which the plywood had been bonded although there a numerous screw holes left behind.
I am looking for advice on two different repair options I am considering for securing the seat post mount to the deck. I plan to use a rectangular 3/4" piece of fiberglass wrapped plywood, about 4" larger than the round post base on each dimension and edge beveled to blend better with the deck under carpeting, that will have ss t-nuts installed on the underside and glassed in place to match the post base mounting hole pattern.
Once plywood is wrapped and cured, the post base can then be secured using the t-nuts with six 1/4" oval head ss machine screws .
Options I am considering for securing the plywood base plate to the deck are:
1. Epoxy it to the fiberglass decking and reinforce top and around the perimeter with two or three layers of cut glass/epoxy, or
2. Use 3M 5200 adhesive between the decking and the fiberglass wrapped plywood base.
Which do you believe would provide greatest rigidity and strength? Any other suggestions I might consider in lieu of my two ideas?
I want to fix it right and not have to go back to redo it for many years to come.
Thank you for your feedback!
