A fellow selling a partly restored 18.6' 1980 DeckBoat brand deck boat made by Anchor Plastics in Gatesville Texas tells me the boat's deck is made of fiberglass rather than wood. Don't know whether it is the "Lo Decker II" model or the "BoatDeck" model. He said it has "The Sportsman" on it. He said it does say "BoatDeck" on it in chrom, but I've seen pictures of several from different years and in different lengths that do too. Looks like Anchor Plastics is out of business. I've seen three threads with owners of these boats, but looks like they all did extensive repairs under the deck. I think, or hope, the fellow I'm dealing with already has.
Is it common for deck boats from that time to use fiberglass rather than wood for the floor? Or does he probably mean there was a plywood floor that was coated in fiberglass?
I wonder how the deck is secured so it could be removed to get at the stringers and foam?
He also mentioned that he glued the new carpet to the fiberglass floor. If so, how could the carpet ever be removed when it becomes worn or mouldy, assuming I wished to keep the fiberglass floor and get rid of the carpet?
Here are the other threads I referred to:
Decker has an 1984 model that seems to have had a plywood floor:
http://forums.iboats.com/boat-resto...om-deck-stringer-replacement-help-471173.html
dennywynn has a 1971 that seems to have had a plywood floor too. Or at least whatever it had rotted. Does fiberglass rot?
http://forums.iboats.com/boat-resto...storation-deck-repair-551045.html#post3786165
dboyd4k seems to have fiberglass on his plywood deck:
http://forums.iboats.com/boat-resto...formation-deck-boat-i-just-bought-354778.html
Or is fiberglassing his new wood deck:
http://forums.iboats.com/boat-restoration-building-hull-repair/decking-357703.html#post2363274
