Re: Riveted Aluminum Hull - Keel repair needed/cracked up front. - need advice
I'm in a similar situation where the PO ground-down a few feet of Keel by running the boat on metal keel roller shafts.
Originally I was going to have it welded however I've since changed my mind since I don't know of a good welder and excessive heat could do more harm than good (if the existing rivet holes expand -> leak).
Inspired by an old iboats thread (i'll see if i can dig it up), I've since ordered a sheet of 6061 aluminum from which i plan to shape, cut and rivet to the keel. I'll add an adhesion layer (JB or MarineTex?) so that I get strong mechanical coupling between the retrofit and existing keel.
