Slacker411
- Apr 12, 2013
- 118
I have a 18 FT Bonito Bowrider with an outboard. In the process of sole, stringer, and transom replacement. I am almost ready to install new materials and have a question about filler materials. I have cabosil, glass microballoons, and un-waxed polyester laminating resin. I need to know if I have to add wax to the mixure to be able to use it as a fairing mix or for fillets that might need some sanding.
A little more info on the boat: Cap is off, sole is out, stringers and transom out, and about 80% of the inside of the hull has been ground to a fresh layer of glass using 36 grit flap disks and an orbital sander with hook and loop 40 grit. Template made for transom, still need to cut the new wood. I got the hollow fiberglass shell once containing the old wooden stringers ground out very close to where they met the hull. Thinking of using them as rough templates vs. scribe and post method. I plan to use 1.5oz CSM, then 18oz woven, followed by another layer of 1.5oz CSM. for the stringer and transom layup. I still need to buy more wood for the sole/deck. I am wondering if downgrading to a cheaper wood for that portion would be on ok idea or not? On the inner sides of the hull there was previously carpet there is all sanded and I plan to sand the rest of the boat down and primer, then paint using an air compressor and 20 oz. HVLP gravity feed spray gun. Will post pics if anyone responds to this message.
