This is my first time using Awlgrip. I am using 545, roll and tip method. Using the proper mix of 1:1 by volume with less than 20% reducer, the <br />primer would dry to quickly to tip it off, adding more reducer thin it so much that it would not cover. Has anyone else had this problem? The weather here is 75 degrees 50% humd. I have seem boats on this site were the same method was used and they looked to be sprayed. I'm not having the same results. Does the topcoat flow better than the primer.
