I am going to be applying Durabak to the whole interior of my 19ft Blue Wave, as well as the Decks, transom, and gunnels (insides).<br /><br />There are a few miscellaneous holes that I am going to want to fill prior to using the durabak, and I was curious as to what I should use/do to fill them up, water tight.<br /><br />Any particular way I need to go about this? 3M 5200, or something else?<br /><br />The holes are about 1/8" diameter, they were used to for 4ea. cooler hold downs (the little corner pieces that you bungee your cooler to). I want to re-position them, and need to fill the old holes.<br /><br />There are also a few other minor holes, similar to this.<br /><br />Any help is appreciated, thanks!<br />Shawn
