Re: 89 Chris Craft Sea Hawk 254
If you're refering to the pds bearings, thats a call you have to make. I suppose you could grease it up.....just remember, if you have the red flywheel cover, it has front and rear bearings, if you have the charcoal cover, it just has one bearing. The red one requires engine removal to replace the front bearing. The charcoal one can be replaced from the rear without engine removal. If it lets go, it could be catastrophic. The bearings are industry standard and can be gotten relatively cheap at Napa and are the same as the VP oem. The procedure is relatively simple and goes a long way for piece of mind.
