Store Links Mobile - Shop Now
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
See more
See less
Home made hard tops?
  • Home made hard tops?
    Has anyone done a DIY hard top for a boat?How'd it go? what materials did you use for the support posts? Top?
    Re: Home made hard tops?
    Yep,It's more of a Simi-Rigid Bimini......Migged up a bunch of Aluminum Conduit, Hospital Bed Parts,+ a couple pieces of a Railroad Crossing Barricade......... Covered it with NATO Tent Material,+ Had Plastic Windows built to close it in........
    • #3
      Call me crazy but, I plan to "TRY" 1" emt aluminum pipe with 1/2" or 3/4" bracing and Alumaloy. The top itself will be 1/4" ply sandwhiched between to peices of plastic used for shower enclosures and rubber u channel capping. I've used the Alumaloy before with good results. I've been studying many tops in my area and have some design ideas. I figure I should be able to build it for under $500 or so. Will be nice to finally get the radar done!
      • #4
        Brian, Yeah, sounds like you are confidant in your materials and skills. Good luck with it. I am going the encapsulated fiberglass route. My top is (hopefully) going to look like the MJM Yachts Z34 downeast sportfisher's hardtop. I am taking some of the style elements, and have adapted many of their structural elements too. their site is www.mjmyachts.com I especially like the size of the windows, and how they are using the vinyl sides and back enclosure...Thanks-
        • #5
          My top will be free standing as my boat is a 23' walk around. I've always like the down east style boats. They have such nice lines. Not too many around here though. I'm keeping a picture log as the transformation goes on.
          • #6
            Thought you guys might like to check out a manufacturer Sharpe Products that makes all kinds of aluminum and stainless elbows, fittings, etc for your hardtop projects. They can even do custom bending for you, so you can get pretty fancy with your designs if you like. The aluminum elbows are Sch. 40 6063 alloy, which has very high corrosion resistance properties.I thought about fabricating a hardtop for my boat as well, but I've run out of time. I may do it this Fall after fishing is over. Please post pictures of your completed projects for others to enjoy. Good luck!p.s. - To the moderators: I am in no way affiliated with Sharpe Products. I've just searched all over the web trying to find parts that would best fit my project and they came out on top.
            • #7
              I would use 1 1/4" EMT if you plan to support a sheet of plywood, I bet the 1" would work but i am always trying to go extra on strength.
              • #8
                I was going to use the 1 1/4" pipe, but the bender is pretty expensive and would only be used for this job. The 1" and 1/2" benders are stock items for Home Depot. I will check a rental place and see if they have one I can rent that would be much cheaper.
                • #9
                  The general rule is that 1" EMT is max that you can bend with a hand bender.
                  • #10
                    Got to tell you guys about the hardtop I saw many years ago on Hilton Head Island, SC. This old fisherman had an OLD 25' Bertram, yeh....it was a hardtop...seems he had cut the top, posts included from an old NASH automobile and attached it. Man, but it did look weird, but it kept him dry. The old salt fished weeky, received a pension from the navy and loved his boat. I think about him from time to time and realize that's what its about,...Fish'in and be damned what anybody thinks about my boat...cause it works for me!B O A T bring on another thousand
                    • #11
                      what about rigid exterior foam insulation coveredwith glass or epoxy? would never rot and wouldn'trequire much support due to light weight?thinking out loud....M.Y.
                      • #12
                        Foam sounds like a good idea. I plan to incorporate an e-box into the design. Nothing real fancy, just enough to hold 2 VHFs and 1 ot 2 other things. I may also do a smaller e-box on the other side of the helm for the sounder, not sure though.
                        • #13
                          If you plan to encapsulate rigid foam insulation (like the kind you can buy at Home Depot) for your hardtop, make sure you use epoxy resin. Polyester resin will eat this type of foam up. Making a hardtop from rigid foam is a good idea because you can easily shape it with a sharp knife. One of the downsides is that it offers no support under the fiberglass skin so it could crush or crack easily. Note that surfboards are made from shaped, rigid foam, then covered with fiberglass mat and resin.
                          • #14
                            Hi, Sorry for no update-Thing go slow. I have designed and cut both sides for the top and have sanded the edges. These other methods seem experimental to me. I bit the bullet and am going with 3/4 marine grade plywood. The weight will not be a factor as I'll use fiberglass to reinforce the joints and encapsulate the whole thing. I MAY use square aluminum tube for the arch under the top uin the back of the top, we'll see. I promise pics when there is something to show.
                            • #15
                              plywood will work, but is pretty heavy. most boatmanufacturers use balsa wood. good luck and postsome pics for us.
