Shallowman
- Oct 11, 2010
- 114
Iam wanting to add a sumped area / bilge area to my boat . I see posts refer to the bilge area to allow water that may have entered the hull drain back to the bilge box area so it can be drained from the boat . My boat is alittle different since its a 2003 Carolina Skiff j 16 , with foam and my understanding is there are supports going from port to starboard side not regular stringers per say . I don't know if its consider a "bilge area" due to this , But mine came without one and i was told it could have ordered with or without one in 2003 , then 2004 / up model came with them .
Ive asked on the CS forum and heard some have added one no issues and others say not to ( no reasons as to why not , other then water could get trapped in the foam --- THIS makes no since as if anything has penetrated the deck or hull , there is currently no way water to exit either ......)
If one shouldn't be added can someone explain to me why ?
Theres a couple reasons i want to add it:
1) I cast net very often and it would allow me to put the bilge pump in the bilge box where the water would go into the bilge box area from the deck vs. having a bilge pump sitting on either side of the flatdeck
2) It would also allow me to clean up transom area by not using a transom mounted livewell pump and the hoses going over the transom
3) I plan on having the interior painted to freshen it up , so now would be the time to add it .
What iam not sure about if added is : do i cut the area out , remove foam and use Marine ply ( glassed ) to make a frame/box then glass that in . Or Just glass right from the deck to the foam after ive cut the area out ?
Iam thinking 8 in x 8 in would be big enough , any thoughts ?
Thanks
Thanks
