Re: Anyone replace transom on a Campion Alert 180?
See I dont really know my project yet or what route I want to take.... just trying to figure it out.
Seeing as it is an OB and I know it will be a PITA to install the wood between the well and the transom, I was thinking about instaling it in 3 pieces. Center section first then the outsides, or the the bottom 1/3 first then slide the tops in. Useing lap joints of course. that way the cap dosent have to be removed or cut.
top corner. treated wood you can see has been attached ontop of the glass on the transom, appears to be that way from the factory
Looking up under the splash well, the bolts you see are the lower bolts on the motor mount
splash well.
