Re: wiring pontoon boat
Buy a fused terminal strip and install it in your captain's stand. Run your negative and positive terminals from your battery to that terminal strip for a start. Then run a pair of wires from the fuse block to each switch for any lights or horns you are connecting, then a pair of wires from that switch to the connected load.<br />One thing I didn't think of until too late. Instead of running the wiring in the pontoon support channels like mine was done originally, I wish I had run all the wiring inside of the side rail channels while I had them off. Wouldn't work any better, but it would be a really sanitary installation.<br /><br />Charles<br /><br />Edit: I forgot to mention. The main wire feed to the fused terminal block should also be fused. I don't know if it is necessary, but I fused both the positive and the negative feed wires.
