Hi everyone,<br /><br />I don't usually post much, but I read the board daily. I have a problem with my project boat. It has a major crack on the port side in what looks to be an outer keel of some sort(is that what it's called?) from where my uncle was an idiot and ran it with a rotten stringer. I was considering just cutting the bad part out. It would leave a rectangular hole in the bottom of the boat about 1 foot by 2.5 or 3 feet long. I was thinking that I could take the old piece and use it to make a mold. Then I could rebuild the piece and put it back in place. I will be using west system epoxy resin for the job. Do any of y'all have any suggestions on what to use to keep the new mold from sticking to the old section and the new section from sticking to the mold. What should I use to fill in the gap between the new piece and the hull? Which type of material should I use to attach the new piece to the hull(woven roving, mat, or cloth)? How should I support the hull to prevent warping until the patch is put in? Does this seem like a good way to do it? This is my first project and I have to say, it's become more of a project than I expected . It's hard to see the extent of damage in the picture, but you can see the worst part. There are also what looks to be stress cracks that extend outward from the "V" to like five or six inches. Here is a link to my boat pictures. The one named "Boat 3" is the one showing the bottom damage. <br /> Boat Pics <br /><br />Thanks,<br /><br />James<br /><br />PS: The boat looked A LOT better when I got it. I discovered major rot though so in I went. I'm almost ready to pull the deck off.
