mwe-maxxowner
Master Chief Petty Officer
- Jun 20, 2012
- 825
I bought a boat that seemed solid. I did everything short of drill holes in it and it seemed good to go. It has a wake tower, tower speakers, looks good and has a good running 4.3. I knew that my situation was still a possibility so I pushed to get the price down to compensate as he'd been trying to sell it for a while. As is the way of things we met somewhere in the middle, so I'm fairly happy with what I paid still.
I finally noticed a slight soft spot way up under the steering console and knew I should investigate. I don't like carpet anyway so I pulled it all up and of course wasn't happy with what I found. Someone had done a half arse partial deck job already that was ugly.
I drilled my stringers around the bilge area that are exposed, motor mounts, and transom and surprisingly all that is not nearly as bad as I thought. A few spots in the transom yield a little darker colored wood but not rotted or nearly as bad as my first Dixie. So, I'd hoped to do a straightforward proper deck job, new foam, and ride. But, after pulling the floor up I saw they put lots of screws into the stringers around the tank causing the wood around the tank to rot.
My plan is as follows:
I don't have the time or the finances to pull the cap and motor and do the transom too as well as the stringers and reinforcements under the motor. I want to replace everything from the bulkhead in front of the motor forward and of course foam it and fiberglass in my deck properly. This replaces everything that is plum rotten and that won't be safe aa bit longer. As soon as next season ends I will build a cradle, pull the cap and rebuild the transom and rear of the boat. That gibes me all next winter to finish and fund the rest of the project.
I know this means cutting up part of the deck I've just done but that'll just have to be so. In addition to the core samples I've also bounced up and down on my outdrive at full up and had someone watch and the transom does not flex. It also does not leak at all.
For those of you maybe reading this as I'm starting the thread bear with me pics are coming.
He hole below for the fuel lines is factory! No wonder these boats do this.
Dunno if you can see all the screws around the tank and the old unglassed nailers.
