Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
Winner minikai
  • Winner minikai
    Hi all
    I'm impressed with all the knowledge and goodwill of the majority of people on this site. Many posts ive read have helped me start a restoration of a 1971 winner minikai.
    This is my first boat and I am thrilled to be working on it(even tearing out rotten transom)! I've got a lot of questions and would greatly appreciate any answers and suggestions. I will start with pictures and questions. Thank you in advance for helping out.
    Re: Winner minikai
    Hi
    Is it possible to post pictures directly from iPhone?
    • #3
      Re: Winner minikai
      Most people use photobucket. I'm pretty sure you can upload them to photobucket from your iphone.
      1980 TideCraft XV-150 Wildfire
      A successful man thinks of ways that something can be done. An unsuccessful man thinks of ways it will not work.
      • #4
        Re: Winner minikai
        Mobile Photobucket
        • #5
          Re: Winner minikai
          Hi
          I removed transom it was rotten.
          The floor seems really strong but I would like to see at least some of it. I drilled out a 3" hole saw to check it out.
          I've searched for a diagram / pictures of a minikai flow to see what fibreglass box stringers layout is. I'd like to cut out a few rectangles ( with saw set at 45 degrees) to inspect, remove all plastic bottles, clean,repair/ put coat of resin on then put 2 part pourable marine foam. Is this a good idea? Will it add a lot of weight (4 lb foam)?
          I'm hoping it will make it stronger and safer.
          Then I would also like to clean, add resin and glass to inside of bow, side walls and floor- to also strengthen it up. Good idea?
          After that I'll paint complete interior and topside with grey brightside. Bow with some anti slip. Also good idea?
          Thanks for looking
          • #6
            Re: Winner minikai
            I forgot that I couldn't really find a diagram or pictures of fibreglass box stringer system. Does anyone know where I'd find info/ pics on it? Thanks
            • #7
              Re: Winner minikai
              Hello M71!
              Restoring an old boat that has seen better days is always a good idea, especially if it has rot.
              Removing your decking and checking for stringer rot is a good thing to do, transom and stringer rot usually go "hand-in-hand". Installing expanding foam is a good thing too.
              You should takes lots of pictures of your boat while you work on it. Take pictures as you take it apart, and then as you put it back together. It's easier for us to help you when you do it this way. Please make your pictures bigger than the little thumbnails you have in photobucket now, some of us are kinda old here and we don't see as well as we used to.
              We need to see the pics as your take your boat apart so we can give you the best suggestions for putting it back together.
              Lookingg forward to seeing this project progress.
              I consider overkill a job well done... plus a little extra.
              There's as many ways to do something as there is people to tell you how to do it... but not all of them are the right way.
              The drinking and debauchery will continue until morale improves... and maybe for a little while after.
              • #8
                Re: Winner minikai
                Thanks Jigngrub
                I'll take lots of pictures.I'm uploading from my iPhone - ill get on my computer and try to post larger pictures directly on thread.
                Cheers
                • #9
                  Re: Winner minikai
                  Hi
                  Im on my laptop trying to upload pictures still failing. I mad a folder just for boat pics on my desktop, from my iphone. Any idea what the problem could be?
                  • #10
                    Re: Winner minikai
                    Yep! More than likely your pics are too large... join Photobucket for free and host your pics there and then post them here for nice big pics like this:
                    • #11
                      Re: Winner minikai
                      Hi
                      Thank you everyone. Ill try this photobucket from my desktop.
                      http://i1355.photobucket.com/albums/...kai7171/b9.jpg
                      • #12
                        Re: Winner minikai
                        Hi again
                        Im having difficulty posting the right size pictures the way you did. is there an easiy way to it? Ill keep trying
                        Thanks
                        • #13
                          Re: Winner minikai
                          <div style="width:480px;text-align:right;"><embed width="480" height="360" src="http://static.pbsrc.com/flash/rss_slideshow.swf" flashvars="rssFeed=http%3A%2F%2Ffeed1355.photobuck et.com%2Falbums%2Fq704%2FMinikai7171%2Ffeed.rss" type="application/x-shockwave-flash" wmode="transparent" /><a href="http://photobucket.com/redirect/album?showShareLB=1" target="_blank"><img src="http://pic.pbsrc.com/share/icons/embed/btn_geturs.gif" style="border:none;" /></a><a href="http://s1355.photobucket.com/albums/q704/Minikai7171/" target="_blank"><img src="http://pic.pbsrc.com/share/icons/embed/btn_viewall.gif" style="border:none;" /></a></div>
                          • #14
                            Re: Winner minikai
                            In the settings for a photobucket acct, you can select AUTO-SIZE
                            Under the pix in photobucket you want to post there are several choices of codes to copy, choose the bottom 1: IMG [code]
                            There's a box next to that w/ an image code that looks something like this:
                            IMG]http://i1246.photobucket.com/albums/bcurt00/2885790271u_1x424x360f1326433034.jpg[/IMG]
                            Copy that code & paste it in your thread posts, and the image appears embedded in you post:
                            I have no idea what you tried to paste into your post above (#13), but it didn't process into a pix
                            Money spent @ Boat Restoration should be measured in Smiles & Pride SHOP IBOATS-BOAT SPECS-FORUM HELP-REPAIR/RESTO
                            • #15
                              Re: Winner minikai
                              Minikai7171's Library | Photobucket
