Re: sealer between layers of an aluminum boat
+1. No need to remove all the rivets. It would be quicker, cheaper, easier to simply buy another boat. However, I would replace any rivets that are obviously bad, or leaking. Most folks here use pop rivets dipped in a bit of JB weld, or 3M 5200. Once all of the rivets have been repaired, you can then paint over the INTERIOR riveted seams of the boat using a 2-part epoxy called Gluv-it. Once cured, it will provide a tough, yet flexible waterproofing barrier that will last for years and years. However, it does require some UV protection, so you'll either need to paint over it and/or install a deck. You can also use any leftover Gluv-it to seal the wooden components of the boat such as the transom and/or sole. Aside from that you don't/should not apply any sort of a sealant between the layers of aluminum. When done correctly, the rivets alone will be water tight.
