Store Links Mobile - Shop Now
No announcement yet.
1961 StarCraft Seafarer/Restoration
  • 1961 StarCraft Seafarer/Restoration
    I recently picked up this fine boat. My first boat, and second restore I hate fiberglass now. Found her on CL for $250. The wood transom was basically dust the bench seats were rotten. I love that she had no holes other than the drain, so with a little persuasion my wife agreed I should get it.
    This is how it looked when I brought it home.
    Click image for larger version
    I believe the transom was the original from when it was built because it was wider at the bottom than the top. The only way I see to put it back that way is to remove the transom braces that are riveted to the hull. I'm no expert but I don't think 3/4" will hurt the strength of the transom. I decided to modify the transom for a long shaft engine, I shaped the filler myself just have to get it tig welded in.
    When I removed the rear bench I found out the seats were solid mahogany and the rear had this tag underneath,, I assume it was placed there by a previous owner . I have Mahogany to put back in I will have to glue up with gorilla glue to get the width I need
    I striped 51 years of paint in 2 days I noted at least 6 different colors. It was a lot of work to get it all off but I'd say all that paint kept the hull from corroding. Heres the cleaned hull
    Now shes ready for paint with a coat self etching primer.
    I the weather will cooperates I'm going to shoot the first coat of Black top coat next weekend, I want to get at least 3 coats.
    Re: 1961 StarCraft Seafarer/Restoration
    Welcome to iBoats! Nice looking boat! What brand of paint are you planning on using?
    1961 Lonestar Flamingo - SPLASHED...Kinda!!
    Fabricating Decks, Stringers, and Transoms
    Paint Your Boat with Tractor Paint...Say What!!!
    • #3
      I'm working with a extremely tight budget, so I poured through this and other forums for low cost solutions. I have chosen to use rustoleum oil based enamel. I hope I don't get flamed for my choice. Perhaps it will last a couple years and I can refinish with a good quality paint. I just doesn't fit my budget to spend 100 or more on paint.
      • #4
        If you can find the hardener in WOG's paint your hull post:
        "Paint Your Boat for Under $100 Bucks"
        The rustoleum paint will hold up for a long time and be extremely hard. Great job stripping the hull!
        Welcome to iboats dry dock.
        Money spent @ Boat Restoration should be measured in Smiles & Pride SHOP IBOATS-BOAT SPECS-FORUM HELP-REPAIR/RESTO
        • #5
          update: 1961 StarCraft Seafarer/Restoration
          First coat of paint sprayed this morning, This info was a great help ("Paint Your Boat for Under $100 Bucks") Thank You!
          enough with the chatter here's the pics.
ID:	7056858Click image for larger version
          • #6
            Re: update: 1961 StarCraft Seafarer/Restoration
            Great looking spray job, how many coats is that so far?
            • #7
              Shiny! Very Darth Vaderey too (Death-Starcraft perhaps?)
              • #8
                If you used the Hardener, she'll be ready for the water in a week. Rocks and Gravel WILL scratch her but touch up is Easy. I think you'll like the paint.
                • #9
                  Thanks! just 1 coat, I'm going to put at least 3 coats. This is my first attempt spaying anything from my Binks gun other than clear lacquer on wood working projects. It looks like an orange peel in places so I have to figure out what I'm doing wrong.
                  • #10
                    followed your guide very helpful!
                    • #11
                      LOL, must come up with a name not sure my wife would like that one.
