I've begun rebuilding a 1991 SkeeterBass boat that has seen better days. Not only is it 20 years old, I think that it was left outside the entire time. Every piece of wood was rotted to dust, and every piece of foam was soaked thru. When I got the boat the 150hp Merc was supported by two steel plates, one under the top hanging attachment, and the other between the jack plate and transom. I've spent the last few months tearing it down and removing the rott and bad glass and am about to start building her back up. Starting at the transom, I found about a 3 inch spider crack thru the hull (highlighted in the picture with pencil for visibility) where the steel backing plate had broken through. This is my first boat rebuild and I want to do it right, and would love the advice of all you great guys so I am not redoing work. After looking at some other posts I am looking at laying a layer of CSM followed by a layer of 1708 biax on the entire flat part of the transom to repair the crack and strengthen the hull. Then I am planning on glueing my two pieces of 3/4" marine ply together with gorilla glue, sealing with poly resin, and gluing the new wood to the Biax with PL, and the finishing as normal (filet edges, CSM, and 2 layers of 1708 biax). Just wondering if this method will work or should i be trying something different. Thanks.
