Roma's Boat
- Aug 7, 2012
- 9
Howdy folks, purchased this 1956 "glass magic" 14' pleasure boat from a buddy for practically nothing in May of 12'. It had a 2 part plywood transom which was completely rotten which started the redux of practically everything. It had these annoying bulkheads at the gunwales which ruined any enjoyment and comfort/access. So I got out the sawzall and hacked away. Then i realized the lower bulkheads were offset at an angle. So i cut them out carefully and trimmed them and put them back making a flat clear view carpet area. This was no easy task. I did a good job re-installing them with 2 layers of mesh and glass. Knowing that I have altered the structure, then came to beefing up the deck and gunwales with 11/2" of custom bent plywood installed under the deck and gunwales. Have yet to put it in the water to see if that is a mistake? As with everything I fabricate, i over do it. Then i got this idea to put 1/2" Walnut on top of all the deck and gunwales as a veneer making a "woody" look. I used spar urethane to coat all the wooden parts except the new transom which is finished with epoxy clear coat. I saved every bit of hardware and add some even for extra armoring using SS fasteners. Hoe did i do? Opinions and comments are much appreciated. This is for my daughter (5) so i still have plenty of time to enjoy it with her. This is also my first boat and first boat remodel.
