I am currently in the process of replacing the floor in my 87 sylvan 17' fishing boat. I noticed the transom was also completely rotten and so I will be replacing that as well. For the floor I am going to tear out the old (keeping intact for template) and replace with MDO. Is 1/2" good enough or go 5/8" or 3/4"?
Should I use MDO for the transom and use 3 pieces of 3/4" to be 2.25" thick total? The motor is an outboard Mariner 80.
Also, for under the floor I would like to do foam blocks to make the ride smoother. I am on a serious budget here and I was thinking about using spray foam insulation. Rather than spray it directly into the hull I was thinking about making my own blocks by spraying it into a cardboard box and pulling them out when dry. Any other ideas on doing the foam blocks?
This is the first time I have messed with a boat and I cannot wait to get it done.
Thanks and any help is greatly appreciated!
