Re: Scrapped bottom of fiberglass boat HELP!
The boat is still functional with no leaks so I can go back in the water anytime. Just bothers me to see the damage on the boat. Its a 1993 Maxum 1700sr with a 3.0L mercruiser alpha one leg.
Bummer.. Spectrum Colors does not supply your gel. The shop should be able to custom color match it (1-2 hours).
The reason why I asked how long til you wanted to be back in the water was considering if you did it compared to a shop. A shop could have that done in 3-4 days. At this time in the season you might be able to find someone to jump on it right away.
Sure you could do it yourself .. If you have a grinder, fiberglass, resin, MEKP, Cabosil, acetone, brushes, bubble roller, respo, suit, glasses, gel, sand paper, air file ( or do it by hand with a long block ), paper cups, stir sticks, paint sprayer ( or 4 preval sprayers ), PVA or wax additive, tape, masking film/paper, buffer + buffing pad, compound and polish, rags, rubber gloves and the willingness to do the repair upside down ( where all this crap is raining down on you ).
Now .. if you get lucky and can find someone to sell you
just what you need in the amount you need it out of this list then your cost will be lower .. if not then your have to buy in Bulk ( expensive ).
If your going to file a claim go with the guy that has the same shop and phone # for the longest ( he is probably the best ). Ask him to go through how he is going to repair the damage. Your color match should be almost right on because its on the bottom of the boat ( less weathered = better match ). Also you will probably get a lot of scratches/gouges done at the same time. Heck he might even give you a few freebee chips somewhere else ( I would
If the shop that you choose says its gonna be a few weeks before he can fit you in .. just ask if its gonna be ok for you to use it until then. I can say that unless you have damage that is worse then whats in the pics or your discription..you can go back on the water until the shop can get you in. Your not gonna have any more water intrusion then what he is gonna grind out anyways.. so its cool.
Good luck
YD.
